2nd PC Build Help
Slowrogue
Commendable
Feb 22, 2016
12
Need a bit of help with this build.
Intel G3258 4 Pentium 3.20 ghz cpu
ASUS H81M-A MicroATX DDR3 1333 mobo
EVGA 500w psu
TESSERACT SW ATX Mid Tower case
Ballistix Sport 8GB (2 x 4GB) DDR3-1600
i already have a hard drive
but theres a couple problems , first is the obvious one , if these parts go well together , and second is im on a tight budget of around $400 , i can get about an rx 460 or gtx 950 just barely going over $400 , but i've heard that theres a gtx 1050 coming out , should I wait for that ? will it be a better upgrade then the 460 or 950 ? and also if i end up being impatient and decide to just buy the parts now , should i go with the gtx 950 ?
kind of leaning towards the rx 460 is it better then the gtx 950 ? the 460 doesnt have many reviews so that somewhat worries me but its sold by Asus on Amazon so i guess thats kind of reassuring
rx 460 on amazon : https://www.amazon.com/gp/product/B01K1JVQI4/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
updated parts list
http://pcpartpicker.com/list/tvxdbj
well yeah i dont really use the front panel usb ports anyways , and how would I do a bios update ?
you're confusing me man , do the cpu and mobo work together or not ?
