2nd Pc has Internet Problems
jaisingh92
22
So. I have never had that problem before. I use a 3 Webgate and it's wired to 2 desktop pcs. Somehow there are problems now with the internet connection. One desktop pc and my wireless connected phone work without problems. But my 2nd desktop pc and my laptop suddenly dont have an internet connection. There is no obvious reason why. Any suggestions?
So, the second PC is plugged in, but the laptop is not?
Check with your ISP on your internet enabled PC to ensure that the gateway is accessible on their end, it could be a connection problem.
Meanwhile, try swapping the ethernet cables between your two desktop PCs and see if there is any difference.
This does sound like an ISP issue though.....
