2way or 3way sli bridge ?
Sazirgaming
20
Hello i bought one more gtx 980 asus strix for my sli setup and im not sure which sli bridge i should get , a 2 way or 3 way ? Should i plug the second card in the second slot or third ? Im a bit worried that it will heath or maybe not even fit in the second slot im using a msı z97 gaming 5 motherboard , my questions are : Will they fit together in the first and second GPU slot because its a bit of a big card , second question is : if they are close together will they have heating problems ? So the short question is should i plug the second card in the 3rd slot or the second slot ?
put the second card in the second slot, there is more then enough room between the two cards on that board. And use the sli bridge that came with the motherboard.
