2x Gtx 570's or 2 Radeon 6950's for gaming? HELP
Dogs666
48
Yeah I cannot decide which graphics card to buy I want to 2-way sli or crossfire whichever is better any help is greatly appreciated. Thanks in advance
iVAT included in the prices...
CPU: Intel Core i5 2500k
CPU Cooler: Coolermaster Hyper 212 +
http://www.overclock.co.uk/product [...] 20490.html
22.50
MOBO: Still trying to decide
RAM: G-Skill Ripjaws X 8GB (2x 4GB) 1600MHz CAS9 DDR3 Dual Channel Kit
http://www.overclock.co.uk/product [...] 36581.html
43.99
GPU: Still deciding
SSD: 128GB Crucial M4
http://www.overclockers.co.uk/show [...] =HD-009-CR
139.99
HDD: Samsung SpinPoint F3 1TB
http://www.overclockers.co.uk/show [...] ubcat=1279
99.99
Optical: Samsung 22x DVD±RW
http://www.overclockers.co.uk/show [...] 10&subcat=
17.99
PSU: Corsair Enthusiast Series TX 850W V2
http://www.overclockers.co.uk/show [...] 23&subcat=
99.98
Case: Silverstone Raven 3 RV03B-W
http://www.overclockers.co.uk/show [...] =CA-075-SV
109.98
I would take a look at the extreme4 gen3 instead of extreme7, I was debating the which to pick from the two for a build similar to yours and went for the extreme4. The features are similar, here are some things worth noticing:
- Extreme7 Gen3 -
Crossfire/sli pcie 2.0 at 16x.
Only one pcie 3.0, cant crossfire/sli with future boards
4 usb 3.0 on i/o rear panel one on header.
xfast usb charging for phones and such (i think the extreme4 has too)
Dual lan ports on i/o
Only has one pci legacy port
6 sata3 ports
-Extreme4 Gen3-
Crossfire/sli with pcie 2.0 and 3.0 at 8x 8x
2 usb 3.0 on rear and one on mobo header
PS/2 keyboard port (extreme7 doesnt have it)
2 pci legacy ports
floppy connector
4 sata3 ports
Everything else is pretty even, unless I missed a minor info there, you gotta see for yourself if for your build and future add-ons if it's worth the extra 75 bucks (or more) to go with the extreme, for my build it def wasn't.
