I have two 2GB DDR2 ram and a A7GM-S MB, I put the RAMs into slot 1 and slot 3, it stucks on the manufacturer screen. Then I try to put them into slot 2 and 4, it doesn't work too. Can anyone help me? I really need to fix this to work>.<
Also, they both are at the same speed at 800MHZ and I've set them at 800MHZ manually in BIOS, still doesn't works.......
