So I just bought a Logitech headset (Logitech Wireless Gaming Headset G930 to be specific) and it's Wireless USB. Well, I was wondering since it's USB that practically means it's for the computer, but I was wondering if I'm able to use a 3.5mm to Female USB adapter to use it on my surround sound? Why I ask, is because I play on a monitor and all, and the HDMI with audio goes to a 3.5mm plug, which my surround system uses to get the audio. Well, also my surround system has a 3.5mm thing for my headphones, which I use a lot (old headphones), but I was wondering if I bought one of those adapters would I be able use it for the USB thing on the headphones from the female USB?
Am I able to do that? Does the USB receiver on the headphones require power, so that option probably isn't possible at all?
If the above is the case, is there any device (probably powered or something so it would work) out there that would be what I'm looking for (have no idea what it would be called or what to look for, to even search on the Internet)? Maybe something of the lines of an adapter (universal?) that is 3.55mm IN and the device has a Female USB OUT, that would be powered, so it would probably work... is there anything out there like that at all?
Why I would like something like this is because I use a monitor to play my Console games, and Netflix, etc., on the consoles, so I have to use that 3.5mm jack for audio. And my surround sound doesn't have any USB things or of that line, just all 3.55mm out jacks and such on it.
Anyway, thanks for your time!
