3 beeps no display signal
Oniel100
50
Just bought a r9 380x and put it in my computer. Computer worked completely fine before this. now the computer has 3 beeps. looked it up it says Base 64K RAM failure. have reset cmos and put my radeon 7950 back in (it was my old card). 3 beeps still happening and i have already gone to computer hope.
Hello... There are methods to Flash BIO's to MB's, Blind... OR RMA of MB with BIO's problems, I've had MB's that needed a New chip installed, nothing else would work... Something Electrical/Mechanical? went wrong with the New card install to cause this kind of failure back to the BIO's.
Can you give the MB brand, TECH support a CALL for you MB problem/error?
i don't think cmos battery is the problem. It still turns on and makes 3 beeps. I've researched this for like 2 hours and it might be a bios problem but im not sure. if someone could confirm it maybe.
its fine my friend is giving me a new processor and motherboard soon. I think this is not only a bios problem maybe a hardware problem. the old card i had performed not as well as it should have. think it might be the board itself. anyways thanks for your help and time (will give you the solution for helping me as much as you did).
