fan splitter, fan hubs, or molex to fan adaptors. pretty cheap options, but the fan hubs can get more expensive as you get more fancy with controllers and such.
check this out i use a couple of these. you can even get molex to 3/4pin adapter where the fan will be powered by the extra molex(4pin) cables you arent using but those ones will always run at 100%. that is probally the most inexpesive and reliable way to get around to powering all the fans. you cna probally find some cheaper ones too if you look around. good luck!
ps dont daisy chain too many splitters from one header on the mobo to avoid the risk of hurting the mobo
