Build:
Motherboard - ASRock X99 Extreme4/3.1
CPU - Intel i7-5820k
Cooling - Noctua NH-D15
PSU - Corsair RM1000x
GPU - cheap Nvidia
Memory - G.SKILL Ripjaws 4 series 128GB (8x16GB) DDR4
Storage - Samsung EVO 2.5" 250GB SSD + WD Blue 1TB HD
I built this solely to run RAM-intensive software. Today, after two days of using the software (CPU 90%+ for 0-4 hours) I tried overclocking the CPU.
Stock speed is 3.3Ghz and after reading around, I found that basically any unit can hit 4.3Ghz without running too hot. I ran Prime95 for 4 hours at stock and temp did not go above 56C or so. I decided to start overclocking by trying 4.2Ghz at 1.2 volts core. Ran the stress test again and got a blue screen after a few minutes. Increased to 1.22 volts and tried again. Blue screen again. Increased to 1.24 volts (still significantly below what is considered safe) and tried again. This time, a couple minutes into the test the computer turns off and I hear sizzling, followed by a flame! I unplug the computer and the flame goes out instantly, and the room smells like burning computer. All temperatures were fine during the stress test - the CPU didn't go above 70C.
After my adrenaline levels go back down to normal, I open the case and take a look. I notice the smell is coming from the top of the case, somewhere near the processor/cooling. I remove the Noctua NH-D15, looks fine. Remove the processor, looks fine. Then I open the back of the case and see a burn mark.
Pictures:
Burn mark on the case in the bottom right
Burn mark on the back of the motherboard, left of the screw
Fire seems to have come from one of these little silver pieces
Another angle - burn marks under the first "9" in "X99"
Was this caused by a faulty motherboard? Did the stress test do something to the motherboard? A combination?
All input is appreciated!
GPU - cheap Nvidia
Pictures:
