i have the following setup:
Ati Radeon HD 5550 installed on express x16 slot.
Ati 9200 PCI card installed on a standard pci slot.
I bought the latter for a 3rd monitor setup since on amd's website, It showed that both of these graphics card used the catalyst control center. But now, when I try to open the catalyst control center software, it says, your current gpu is not supported. So I have uninstalled the catalyst software.
I have 3 displays working(spanning), however, i am only able to change the resolution for the monitors connected to the ati 9200 through display properties. Display props does not show a 3rd monitor. The other monitor connected to the ati hd 5550 has a huge resolution which I cannot change thru windows xp. How do I do this?
thanks
thanks
