I have a ASUS ROG Zenith Extreme motherboard that takes 4 slots for GPUs.
I have an RTX 2080(Gigabyte GeForce RTX 2080 8GB Windforce) and an RTX 2060( MSI GeForce RTX 2060 6GB Ventus OC).
Both have 3 and 2 fans respectively and not a blower type but the fans are on one side with the big area(just like in the picture for the 2080 Ti below).
I want to put 1 extra RTX 2080 Ti (Asus GeForce RTX 2080 Ti 11GB ROG Strix OC--see the picture below).
I just want to ask if i can fit the 3 GPUs in there?
My main problem and question is ok they fit all 3, but by putting 3 or more, then at least 2 GPUs will be VERY close to each other so the fans of one will be just 1-2 mm away from the next GPU. Isn't this gonna create heating problems??
Shouldn't the fans have a big space for air?
Do i need a blower type of GPU necessarily to throw air from "outside" side of the card or the below GPU will have no thermal problems too?
The extra GPU i want to put is this:
