3 monitor 1 dvi-split into 2-then 1 hdmi is it possible
jake0207
im running a r7850 twinforce 2gd5/oc
what plugs i currently have are 1 hdmi 1 dvi. 2 dp-
i bought a y spliter
http://www.amazon.com/gp/product/B004OOQNHM?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00
kenable DVI Splitter Cable - Splits the DVI-D signal to Twin DVI Monitors GOLD
Gold Plated Contacts - for a better connection
DVI Splitter Cable, Splits the DVI-D signal to 2x DVI Monitors
24 + 1 Pin DVI-D Male connection
24 + 5 DVI-D Female Connection
Dual link
Gold Connections
cable lengths approx 23cm
im running a hdmi 39, then im wanting to use my dvi splitter to split into two extended displays.
did i order the wrong one??
A DVI splitter will clone the signal, so both monitors will display the same thing, it will not create 2 independent monitors. Your video card will support 3 monitors but the 3rd has to use displayport, if your monitors don't have a displayport you can use an active displayport to dvi or hdmi adapter.
