Question 3 monitor display with Dvi?
TripleStack
22
Hey, i have the MSI 970 twin frozr 4gb, which has a 1x display port, 1x HDMI, 1x DVI-D 1x DVI-I.
My current monitor set up is
Monitor 1: LG 25UM58-P 25-Inch 21:9 UltraWide FHD IPS Monitor - USING HDMI
Monitor 2: Samsung S22F350 22-Inch HDMI LED Monitor - USING DISPLAY PORT TO HDMI
Monitor 3: Some AOC 720p monitor - USING DVI-D TO VGA
i want to upgrade the AOC monitor to a 1080p 22" S22F350, same as monitor two.
i was sure if i use a dvi-d or dvi-i converter to HDMI if there would be a big quality drop?
If i did do this would it be better to use dvi-d or dvi-d
My motherboard ASUS® P9X79 LE: INTEL® SOCKET LG2011 also does not have any video outputs on it, the graphics card is all i got.
You can use passive DVI->HDMI adapter. No quality drop with it.
