3 monitor hook up
revachtung
I have 2 LED pc monitors, and one 52" LCD tv in the living room. All 3 are HDMI.
Is there a way of hooking up all 3 to my pc (2 AMD 5890s in CrossFire mode) where: a) 1 pc monitor is the 'default' one, b) the 2nd pc monitor is an extension of the default one, and c) the 52" is a clone of the default monitor.
Hopefully I didn't confuse anybody and that I described what I want properly.
Thanks for your quick responses!
I've confirmed that you can set it up that way. I was able to choose which monitor I wanted to duplicate. Once you have the adapters needed, you should be able to do it, no problem.
