3 monitor set up. 2 in GPU, 1 in integrated. Resolution issue;
Esrue_Arlo
Commendable
Mar 2, 2016
5
Hello,
I recently bought a 3rd monitor and wanted to give a 3 monitor set up a go. I was dismayed to find out my graphics card (R9 280x) usually only supports 2 unless i have another cable for an active slot, which sadly i didn't. I was prepared to just use 2 monitors (I won't have to luxury of spending for a small while because of other numerous purchases) when i found out you can route the monitor through the integrated graphics in the MoBo.(MS-7641)
My set up worked and all 3 monitors cut on... but sad to see my monitor routed through the integrated graphics won't go over 1024x768 while it's native resolution was 1600x900.
I tried numerous things but can seem to make it work I even found drivers i believed to help out the issue because the integrated graphics are of the MSI AMD 3000 series but it doesn't seem to be helping, the resolutions won't change for the one routed through the integrated.
Any suggests or experience would be greatly appreciated.
This is windows 10. It identifies the monitor by its name, but no matter what i do it won't show up in the catalyst.
