ALL PICTURES ARE BELOW
Wow just typed a long message just to hit ctrl-z and then ctrl-r to delete the entire thing.
Here I go again...
When creating my account I detailed all of the specs for my computer so I hope to only reference the pieces and that be enough to guide anyone reading, if not I can specify.
I have three monitors as of late and I would like to successfully run games across all three when possible. I plan to accomplish this using:
1. EVGA gtx 770,
2. BenQ 27" 120hz 1920x1080 -DisplayPort
3. Asus 23" 60hz 1920x1080 -Dvi
4. Acer 21.5" 60hz 1650x1050 -Dvi
5. Various other PC specs
6. Windows 8.1
When plugged in each monitor works perfectly fine, on the correct resolution, and aspect ratio, all at the same time.
I run into trouble when turning on NVIDIA surround. My outer monitors (Asus and Acer) have the correct resolution displayed, but the BenQ in the middle loses the 1080p and changes to 1024x1024 (Or something really close). The problem with this is obvious, it leaves large black bars on the left and right of the picture creating a large gap between monitors. I can stretch the picture, but the look is atrocious and unplayable.
If my math is correct, my optimal resolution should be about (1920+1920+1650= 5490)x(1080~)
so 5490x1080 or 5490x1050.
With surround on the highest resolution I can apply seems to be 3840x1024, also the resolution in the second picture below.
What I already have (tried) :
Updated Drivers
Different resolutions
Different hz (Including one I have seen work for other people: 60.0001 hz)
General tinkering around with settings.
any help or advice would be great;y appreciated, if I forgot to include anything, just ask, or check my profile for specs.
Thanks a ton in advanced!!!!
Zac R.
Without Surround, no problems:
With Surround, Problems
Here I go again...
1. EVGA gtx 770,
6. Windows 8.1
Updated Drivers
Zac R.
