jcorqian Distinguished May 7, 2008 143 0 18,680 Aug 22, 2008 #1 Can you install a 3 pin connector for a CPU fan on a 4 pin motherboard connector? I know it fits physically, but does everything work fine?
dallasjoh Distinguished Oct 8, 2007 496 0 18,790 Aug 22, 2008 #2 Yes, it will work, but depending on your motherboard, it may run at full speed. Check out the link on the different types of fan connections. http://www.analog.com/library/analogDialogue/archives/38-02/fan_speed.html
L lasttarget Distinguished Jun 14, 2008 129 0 18,680 Aug 22, 2008 #3 The guy above me gave you too much info. Just go to this website to see how to control the fan speed. http://www.hardwaresecrets.com/article/496/3 The problem is that the fan maybe to loud without sound control(the fourth pin)
jcorqian Distinguished May 7, 2008 143 0 18,680 Aug 23, 2008 #4 Well the fan does have a manual fan speed control, so everything is fine. Thanks fellas.
