Does anyone know if I can plug a 3 pin fan (non noctua fan) into a 4 pin low noise adapter from noctua and then connect it to my motherboard. The 3 pin fan is currently plugged directly into the mootherboard and it works fine, it's just loud as heck , but my noctua fan is silent without the low noise adapter. So i'm considering using the low noise adapter on the 3 pin fan. is it safe/possible to use the 3 pin fan with the noctua low noise adapter? has anyone tried this?
