Question 3 Pin Fan Not Working ?
May 30, 2020
Hi! I installed an Arctic P14 silent into my build today and everything is connected correct but my Bios or any other program isn’t picking it up? If it helps i have a ASUS Prime A320M-K motherboard :)
Karadjgne
Ambassador
Have you tried looking in bios or other software you might use and see if the voltage is set too low for the fan or is disabled? It should have come on at least temporarily.
You can test if it's a motherboard issue or fan issue by temporarily swapping it to a header you know is actually working, that already has a fan on it. There's always a possibility it is DOA.
