3 Pin Fans Connected Into 4 pin splitter
YANKEEEZILLA
48
So I have two Corsair AF120mm fans in my case. They make alot of noise considering my room is always quit. I want to purchase this:
https://www.amazon.com/gp/product/B01GZPEQW6/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A28RI4FXFS5SV8
I want to buy a pwm fan and connect the two non-pwm fans into that hub as well. In doing this, I hope by regulating the pwm fan, I can manipulate the speed of the non-pwm fans as well. Will this process work? Or because they are two non-pwm, they cannot be regulated by a hub. Thanks for the feedback guys, I really appreciate it.
Gam3r01
No, that wont work the way you plan.
All that hub does is split the PWM signal to 4 fans, the fan itself still has to take advantage of that signal.
The only way to manage 3 pin fans is voltage control (certain motherboard headders can do this)
Gam3r01
Doramius
179
22
For a PWM hub you MUST use PWM fans or it will not work correctly. The Data signal will not report properly. Some people think that they'll all run at the speed of the PWM fan, and most of the time they just don't come on. This option is probably the best for the fans you have, instead: https://www.amazon.com/dp/B014R2EAUW/ref=olp_product_details?_encoding=UTF8&me=
Wish I had a better answer, but didn't want you to waste time and money on something I already learned the hard way years ago.
Latest posts
