i recently bought some case fans for my pc, they are all 3 pin connectors. However the fan hub i have bought is connects to the motherboard using a 4 pin connector. Does this mean i will still be able to control fan speeds or not?
yes that will be fine, usually you just need to tell bios to turn on fan management on and your set, the motherboard fan software will see and mange them just fine, the 3pin plugs into the 4 pin , just watch for the slot to fit into the slide and your good to go
