my motherboard (asrock 970 pro3.0 r2.0) has only 3 fan headers with speed control, of which 2 are cpu fan headers, and the only one that is not is a chassis fan 1 header. so, if i were to plug in a 4 pin case fan into cpu_fan 2 (which is a 3 pin with voltage control), and a 3 pin into the 4 pin cha_fan 1 header, would it work? would i be able to control those? also, how do i make a fan curve in speedfan? nothing works.
