3-Pin to 2-Pin Fan Adapter
jackman9061
42
I have a thing that can only accept 2-Pin Fan Connectors and the problem is I need a 60mm fan with 5 Volts of power and it needs to be a fan with a 2-pin connector. And the fan has to be as quiet as possible, the Noctua NF-A6x25 5V is a close match, but it doesn't have a 2-Pin connector.
So I either need a fan that follows all those requirements or a 3-pin to 2-pin fan adapter.
D
if you want Noctua's performance and quality then you can try connecting the NF-A6x25 5V but making sure that its the red & black wires connecting, could work.
Another option if that doesn't work and you have bought the NF-A6x25 5V would be to use the included adapter set that comes with the fan.
Connect the 3pin from the NF-A6x25 5V into the adapter then connect the red & black wires up with a 2pin cable using the joiners. You will have to purchase a 2pin cable separately or purchase a 2pin fan which you can take the cable off of. This is the expensive option but worth it.
https://noctua.at/en/nf-a6x25-5v
https://noctua.at/en/omnijoin_adaptor_set
Otherwise...
Otherwise, https://www.amazon.co.uk/Move-Moving-TM-Cooling-Cooler/dp/B00XL5LVB8/ref=sr_1_2?ie=UTF8&qid=1517513943&sr=8-2&keywords=5v+case+fan+60mm
