APPROXIMATE PURCHASE DATE: ~3 weeks BUDGET RANGE: $300 to $400 should be enough,
USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Internet usage, Movies, Coding/Work,
PARTS NOT REQUIRED: Mouse, Monitor, Speakers, Power supply (400-500 Watts, I think), OS (windows XP), OEM blu-ray drive. The HD is compatible with SATA. Case is an Ultra (?) ATX Mid-Tower, compatible with Micro ATX, AT, and Baby AT.
NOT SURE IF I SHOULD KEEP WITH THE NEW BUILD OR SELL/THROW OUT: I'm currently using 2 1gig sticks of DDR2 RAM--is a a motherboard that handles DDR3 RAM going to be backwards compatible with my DDR2 sticks. My GPU is an EVGA eGeForce 8800 GT--my monitor is HDMI compatible, but my video-card isn't: is it worth upgrading?
PREFERRED WEBSITE(S) FOR PARTS: No real preference, I have accounts with the majors players. But I am open to others if the prices are better.
PARTS PREFERENCES: I grew up buying intel chips, call it sentimental value only. Realistically, whatever gives the best price/performance.
OVERCLOCKING: No SLI OR CROSSFIRE: Don't know what they are, and I'm not looking for a fight.
MONITOR RESOLUTION: Monitor is Dell 2408WFP, http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=gen&sku=320-6272#Overview
Not sure what an ideal resolution is for a wide-screen monitor, maybe you can make a suggestion?
ADDITIONAL COMMENTS:
I've been building my own machines since high school just by shopping around, and the last time I made a motherboard/CPU/RAM purchase was about three years ago. I'm looking for a compatible build with most of my hardware so that I can just upgrade my mobo, CPU, and possibly RAM/GPU, if necessary. I'm looking to put together a build to play first person shooters from 2010-2011. I don't need to see the reflection of my avatar in my eye, I just want a playable frame rate.
As a side comment, if I could get some information about installing quiet cooling systems, I'd be appreciative too.
I'm still not sure where to start as far as processors/motherboards. I don't know whether it's worth keeping or trashing my graphics card, and I would like opinions on the following:
MotherBoard:
ASUS F1A75-M FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131768
Processor:
AMD Phenom II X4 840 Edition Deneb 3.2 GHz 4x512 KB L2 Cache Socket AM3 95W Quad-Core Processor - Retail
http://www.amazon.com/dp/B004LRO9B4/ref=asc_df_B004LRO9B41705246?smid=A7GTBCGAH5STZ&tag=pg-408-34-20&linkCode=asn&creative=395133&creativeASIN=B004LRO9B4
RAM:
Patriot Viper II PGV34G1600ELK 4096MB PC12800 DDR3 Dual Channel Memory Upgrade - 4GB (2 x 2048MB), 1600MHz
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5210472&Sku=P33-7108
Is the DDR2 RAM going to be compatible with the DDR3 MoBo I'm going to buy?
None of these are set in stone!! I'm just looking for advice, how to get the best "bang for my buck" and some direction where to take this build.
Thanks a lot for your free advice, it's really appreciated!
MotherBoard:
Processor:
RAM:
