Hello there! I am planning on ordering a new build tonight and have been researching for quite some time now exactly what parts I require for what I am looking for. I plan on spending $3000-$3500 hard earned bones on this build, plan to 3d game at 1080p, and hopefully build the SLI'd Battlefield 3 max settings destroyer I have been dreaming about for quite some time now! I will list the parts I'm thinking of and I would really love it if any of you more experienced builders out there could comment and give me advice if you believe I would be better off with different parts here and there! I do plan on overclocking but this will be my first time trying it so I'm a little nervous but I think with my motherboard, cpu and cpu fan chosen it hopefully won't be too big of an issue... Anyways, without further ado... The specs!
Case:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
HDD:
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
3D Monitor:
Acer HN274Hbmiiid Black 27" 2ms 3D Full HD HDMI WideScreen LCD Monitor w/Speakers 300 cd/m2 ACM 10,000,000:1
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009300
Video Cards x2 For SLI:
EVGA SuperClocked 015-P3-1582-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130590
Power Supply:
Antec High Current Pro HCP-1200 1200W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371043
Memory:
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
Motherboard:
ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157265
CPU:
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
OS:
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
CPU Heatsink:
COOLER MASTER V6 GT RR-V6GT-22PK-R1 120mm DynaLoop CPU Cooler w/ Universal bracket & Dual Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103089
I also have an extra Cooler Master fan in there for the top of my HAF case, and thermal paste.
I've heard the Cooler Master V6 is absolutely massive and takes up the space of the first memory slot on most boards, could i put my memory in the 2 and 4 slots?
Thanks for your advice guys I appreciate any help or reassurance that im making good decisions, this is an expensive purchase haha!
Comes out to about $3000 with shipping
Case:
HDD:
3D Monitor:
Power Supply:
Memory:
Motherboard:
CPU:
OS:
CPU Heatsink:
