[SOLVED] 3000 speed memory only running at 2400
acemagoo77
24
Lenovo Thinkcentre M725s AMD Ryzen 5 Pro 2400G
Motherboard is Lenovo 3141 B450
Memory is
TEAMGROUP T-Force Zeus DDR4 16GB Kit (2 x 8GB) 3000MHz (PC4 24000) CL16
Can not get it to run over 2400 in dual channel or single channel (running at 1192 per stick)
There is NO bios options for memory
Info states the MB and CPU can run up to 2666-2933
We all know these APU's like ram speed so i would like to get it to run at the 2933 or atleast 2666 if i can..
Any idea's?
EyyMunchian
314
30
10,940
36
Looks like you cannot run at those speeds. You said your Mobo has no XMP capability. well looking at your
Max JEDECDDR4-2400 (1200 MHz)
I see that that is the default operating frequency of your memory. Your memory has 3000mhz only with XMP enabled. To sum it all up, 2400 is the highest speeds you can get.
EyyMunchian
314
30
10,940
36
Memory is
Any idea's?
Are you able to share a screenshot of the SPD panel from CPU-Z? Your system might be running in jedec profiles and unable to find the XMP profiles
CPU-Z | Softwares | CPUID
acemagoo77
24
CPU-Z
Binaries
CPU-Z version2.03.1.x64
Processors
CPU Groups1
CPU Group 08 threads, mask=0xFF
Number of sockets1
Number of threads8
APICs
Socket 0
-- Node 0
-- CCX 0
-- Core 0 (ID 0)
-- Thread 00
-- Thread 11
-- Core 1 (ID 1)
-- Thread 22
-- Thread 33
-- Core 2 (ID 2)
-- Thread 44
-- Thread 55
-- Core 3 (ID 3)
-- Thread 66
-- Thread 77
Timers
ACPI timer3.580 MHz
Perf timer10.000 MHz
Sys timer1.000 KHz
Processors Information
Socket 1ID = 0
Number of cores4 (max 4)
Number of threads8 (max 8)
Number of CCDs0
ManufacturerAuthenticAMD
NameAMD Ryzen 5 PRO 2400G
CodenameRaven Ridge
SpecificationAMD Ryzen 5 PRO 2400G with Radeon Vega Graphics
PackageSocket AM4 (1331)
CPUIDF.1.0
Extended CPUID17.11
Core SteppingRV-B0
Technology14 nm
TDP Limit65.0 Watts
Core Speed1595.7 MHz
Multiplier x Bus Speed16.0 x 99.7 MHz
Base frequency (cores)99.7 MHz
Base frequency (mem.)99.7 MHz
Instructions setsMMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision0x8101016
L1 Data cache4 x 32 KB (8-way, 64-byte line)
L1 Instruction cache4 x 64 KB (4-way, 64-byte line)
L2 cache4 x 512 KB (8-way, 64-byte line)
L3 cache4 MB (16-way, 64-byte line)
Max CPUID level0000000Dh
Max CPUID ext. level8000001Fh
FID/VID Controlyes
# of P-States3
P-StateFID 0x890 - VID 0x10 (36.00x - 1.450 V)
P-StateFID 0xC8A - VID 0x5C (23.00x - 0.975 V)
P-StateFID 0x1080 - VID 0x6C (16.00x - 0.875 V)
PStateReg0x80000000-0x49040890
PStateReg0x80000000-0x45D70C8A
PStateReg0x80000000-0x441B1080
PStateReg0x00000000-0x40160000
Package Type0x2
Model00
String 10x0
String 20x0
Page0x0
Power Unit0.0
SMU Version30.87.00
TDP/TJMAX0x0
TCTL Offset0x0
Temperature 034 degC (93 degF) (Package)
Voltage 00.85 Volts (VID)
Power 003.13 W (Package)
Power 010.02 W (Cores)
Power 020.00 W (Core #0)
Power 030.01 W (Core #1)
Power 040.05 W (Core #2)
Power 050.00 W (Core #3)
Clock Speed 01595.74 MHz (Core #0)
Clock Speed 11595.74 MHz (Core #1)
Clock Speed 21595.74 MHz (Core #2)
Clock Speed 31595.74 MHz (Core #3)
Core 0 max ratio(effective) 39.00
Core 1 max ratio(effective) 39.00
Core 2 max ratio(effective) 39.00
Core 3 max ratio(effective) 39.00
Chipset
NorthbridgeAMD Ryzen SOC rev. 00
SouthbridgeAMD B450 rev. 51
Bus SpecificationPCI-Express 3.0 (8.0 GT/s)
Graphic InterfacePCI-Express 3.0
PCI-E Link Widthx16 (max 16x)
PCI-E Link Speed8.0 GT/s (max 8.0 GT/s)
Memory TypeDDR4
Memory Size16 GBytes
Channels2 x 64-bit
Memory Frequency1197.4 MHz (1:12)
Memory Max Frequency1466.7 MHz
CAS# latency (CL)16.0
RAS# to CAS# delay (tRCD)16
RAS# Precharge (tRP)16
Cycle Time (tRAS)39
Bank Cycle Time (tRC)55
Command Rate (CR)2T
Uncore Frequency1196.8 MHz
Memory SPD
DIMM #1
SMBus address0x52
Memory typeDDR4
Module formatUDIMM
Module Manufacturer(ID)TEAMGROUP Inc. (7F7F7F7FEF000000000000000000)
SDRAM Manufacturer (ID)SK Hynix (AD00000000000000000000000000)
Size8192 MBytes
Max bandwidthDDR4-2998 (1499 MHz)
Part numberTEAMGROUP-UD4-3000
Serial number0104896D
Manufacturing dateWeek 11/Year 22
Nominal Voltage1.20 Volts
EPPno
XMPyes, rev. 2.0
AMPno
EXPOno
JEDEC timings tableCL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #110.0-11-11-25-35 @ 766 MHz
JEDEC #211.0-12-12-27-38 @ 833 MHz
JEDEC #312.0-12-12-29-41 @ 900 MHz
JEDEC #413.0-13-13-31-44 @ 966 MHz
JEDEC #514.0-15-15-35-49 @ 1066 MHz
JEDEC #615.0-16-16-37-52 @ 1133 MHz
JEDEC #716.0-16-16-39-55 @ 1200 MHz
JEDEC #817.0-16-16-39-55 @ 1200 MHz
JEDEC #918.0-16-16-39-55 @ 1200 MHz
XMP profileXMP-2998
SpecificationDDR4-2998
VDD Voltage1.350 Volts
Min Cycle time0.667 ns (1499 MHz)
Max CL16.0
Min tRP12.00 ns
Min tRCD12.00 ns
Min tRAS25.25 ns
Min tRC37.25 ns
Min tRRD3.70 ns
XMP timings tableCL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #115.0-17-17-36-53-n.a @ 1411 MHz (1.350 Volts)
XMP #216.0-18-18-38-56-n.a @ 1499 MHz (1.350 Volts)
DIMM #2
SMBus address0x53
Memory typeDDR4
Module formatUDIMM
Size8192 MBytes
Serial number010489AE
EPPno
XMPyes, rev. 2.0
AMPno
EXPOno
XMP profileXMP-2998
Max CL16.0
Min tRP12.00 ns
Min tRCD12.00 ns
Min tRAS25.25 ns
Min tRC37.25 ns
Min tRRD3.70 ns
EyyMunchian
314
30
10,940
36
