Question 300W TFX PSU with 10 Pin + 4 Pin, for IdeaCentre 510A
llinfeng
4
Shorter question: is there a tested PSU upgrade for IdeaCentre 510A? Here is what I am looking for:
I bought this Ideacentre 510A and have just figured out that I need a 300W PSU to get a VisionTek 7750 Graphics Card to work with 4 monitors. The graphics card listed "300W power supply" as its minimum requirement, although I am booting 3 monitors from it on a 180W PSU from the IdeaCentre machine. I contacted VisionTek and figured out that I shall need a stronger PSU to boot up all the 6 video outputs from the card.
I have tried one PSU from Silverstone, which has standard 20(24) Pin + 4(8) Pin Pinouts. Yet, on the motherboard, there are 10 Pin + 4 Pin receivers. I cannot physically fit the 20-Pin Pinout to the 10 Pin slot, both for the fear of frying things and also due to two nearby sockets that blocked the 20-Pin Pinout to reach the end.
I tried Amazon and did not find any listing that matched the search criteria: TFX, 10pin + 4pin. Looking forward to a recommendation.
