[SOLVED] 3060ti and i7 11700k build
Nov 26, 2021
8
I'd like to request help with finishing this build.
I'd like to overclock the CPU, so a strong enough motherboard will be required. The rest I can cheap out on.
I need the PSU, RAM, CPU cooler, tower and motherboard. I might be able to salvage an SSD from my laptop, but if you have a recommendation for that please go for it.
Thank you so much in advance.
keith12
Illustrious
When I click on the link it sends me to my shopping cart which consists of a badminton net. I am guessing that is not what you are trying to show me lol
No!!!
Qty: 0 (Delete) 12345678910+ Qty:1
¥8,618
Amazon Points: 86pt (1%)
¥16,551
Amazon Points: 166pt (1%)
¥9,509
Amazon Points: 95pt (1%)
¥9,258
Amazon Points: 93pt (1%)
¥15,827
Amazon Points: 158pt (1%)
¥10,980
Amazon Points: 110pt (1%)
Subtotal (6 items): ¥70,743
Points to be earned: 708pt
Reactions: Noobytunes1
keith12
Illustrious
Hey there,
Where are you living? What budget have you got for the other parts? Whilst you can get lower end parts, with a strong system like that you will also need a quality PSU. That's one thing I wouldn't cheap out on.
Psu....there are psu tier list you can look at....use google.
Best to stick with tier A or B.
I would recco 700w minimum.
Nov 26, 2021
8
Hey there,
Where are you living? What budget gave yo got for the other parts. Whilst you can get lower end parts, with a strong system like that you will also need a quality PSU. That's one thing I wouldn't cheap out on.
I am living in Japan. I have the budget to build a fine ass PC, but would like to get the best bang for my buck on the cheaper alternatives. I'll take your PSU recommendation seriously
keith12
Illustrious
If you point us to store you purchase from, I'm sure we can find you something.
In terms of PSU, a decent 650w will do fine. Whilst wattage is important, quality is what you want. Corsair RMx/RMI/RM 650w, EVGA G2/G3, Seasonic Focus plus Gold, are all great PSU's with long 7-10 year warranties, and are fully modular for nice cable management.
Nov 26, 2021
8
I am planning to buy from amazons japanese site. There is also a pc parts store nearby which I could go to but they have limited selections, either way that is where I bought the 3060ti for 650USD so I might revisit the place soon. Thank you so much for the PSU information, it good to know those specific ones will work
keith12
Illustrious
No probs, you are welcome :)
Something like this:
Amazon.co.jp Shopping Cart
keith12
Illustrious
No!!!
¥8,618
¥16,551
¥9,509
¥9,258
¥15,827
¥10,980
Nov 26, 2021
8
No!!!
¥8,618
¥16,551
¥9,509
¥9,258
¥15,827
¥10,980
Thank you again for all these recommendations. My brother in law also recommended lian li towers to me because of their air flow which is what I want. Quick question, will that motherboard be able to handle the overclocked CPU with no problems? I would really like if it were able to as I'd like to get my money's worth for the CPU.
Phaaze88
Ambassador
Neither that cooler nor mobo are adequate for that goal. If OC'ing wasn't part of the requirements, at least the 240mm cooler would've been fine.
Need a 280mm or larger for that cpu, as when you go to benchmark or stress test all the cores for OC stability, it's going to overwhelm a 240mm.
Motherboard's a no-go:
View: https://youtu.be/w594enhi0vs?t=623
(saved at 10:23)
Yes, it's an 11900K in the video, but that cpu is pretty much a higher binned 11700K. It's going to be able to get by with lower voltage settings.
Nov 26, 2021
8
I am settling for the mid lian li tower, the PSU and ram. Any help with a 280mm cooler and Mobo for overclocking would be greatly appreciated.
Nov 26, 2021
8
After much thought and consulting with a friend, I am no longer planning to overclock as of now. Being a beginner and also after researching the games I'll be playing, the overclock would not be needed/not in my best interest as beginner.
With that said, I am inviting anyone else with knowledge to provide their input on recommendations. I am sticking with the Lian Li case provided by Mr.Keith.
No need whatsoever to overclock this cpu.
LIANLI LANCOOL 215X ¥8,618
SUPER FLOWER LEADEX III 80+ GOLD 650W Power Supply ¥12,000
CORSAIR ML120mm 4-Pin Case Fan ¥2,351
GIGABYTE Z690 UD DDR4 ¥28,058
https://www.dospara.co.jp/5shopping/detail_parts.php?bg=1&br=11&sbr=1481&mkr=2&ic=475991&lf=0
Intel Core i5 12600KF ¥37,000
Cooler Master MasterLiquid ML240L V2 RGB AIO CPU Cooler ¥9,258
CORSAIR VENGEANCE LPX DDR4 3200MHz 16GB (2x8GB) CL16 ¥7,147
https://www.gigabyte.com/Motherboard/Z690-UD-DDR4-rev-10#kf
https://www.techpowerup.com/289205/gigabyte-releases-drm-fix-tool-for-intel-alder-lake-processors-to-dynamically-park-and-unpark-e-cores
https://www.newegg.com/cooler-master-603005870-gp/p/N82E16811999416
Reviews of that cpu including benchmarks.
https://www.guru3d.com/articles_pages/core_i5_12600k_processor_review,1.html
https://www.tomshardware.com/news/intel-core-i5-12600k-vs-amd-ryzen-5-5600x-ryzen-7-5800x-cpu-face-off
i5 12600K = best overall cpu & best gaming cpu for 2021
View: https://www.youtube.com/watch?v=7_ZAdsAUN7s
