Question 3060ti Gigabyte OC 8GB V1 fan searching help
Iga
20
Guys i cant find fan model Apistek GA81S2U PFTD 0.38A. No luck finding it on ebuy or aliexpress. I ordered simmilar fan from 3060 model but it cant fit.
Iga
20
https://www.aliexpress.com/item/32876071501.html
https://www.ebay.com/itm/154424605690
They don't have the Gigabyte logo, but should be the same fan? They match the info on the back of your fan, right?
Thanks for you reply. That fan maybe should do the job, but the cable is to short.
Here is the screenshot similar to what i need, what is inside my card.
https://prnt.sc/1yzrbtc
There is that long 4 ping that i need, and the other 4 pin where are two other fans.
Iga
20
So your gripe with this one is that you get three fans? You just want the one fan? Would just get the three, but that is me.
One you need you broke it?
Its also fine for me to buy all three, am just trying to explain what kind of fans i need. So i have two 4pins on gpu, one with two 4pins, and second with long 4pin :)
Sorry if am confusing you
