[SOLVED] 3070ti - power supply
techynoobie
6
Hi,
I've just purchased a 3070ti (Gigabyte - Aorus Master), and it has 3 power connector slots: 2 x 8 pin & 1 x 6 pin.
I've run 2 leads from my modular power supply; using both connectors on 1 lead & 1 (of 2) connectors.
Is this okay?
Thanks.
Hi,
Is this okay?
Thanks.
Probably. It would be better if you listed the brand, model and age of your power supply to be sure.
What's the make and exact Model number of your current PSU ? How many PCI-e 6+2 PIN cables are there in it ? Post a pic of the installed GPU and cables as well, if possible.
