Question 3080ti - but is my build going to bottleneck?
putern00b2020
26
PCPartPicker Part List: https://pcpartpicker.com/list/Cz6KW3
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($272.66 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler ($86.99 @ Amazon)
Motherboard: Asus ROG Strix X570-E Gaming ATX AM4 Motherboard ($329.00 @ Amazon)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($178.99 @ Amazon)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive ($144.15 @ Amazon)
Video Card: Asus GeForce RTX 3080 Ti 12 GB TUF GAMING OC Video Card ($2168.88 @ Amazon)
Case: Cooler Master MasterBox TD500 Mesh w/ Controller ATX Mid Tower Case ($123.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($117.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($108.78 @ Other World Computing)
Monitor: Asus TUF Gaming VG27AQ 27.0" 2560x1440 165 Hz Monitor ($329.00 @ Amazon)
Total: $3860.43
Generated by PCPartPicker 2021-09-22 22:56 EDT-0400
putern00b2020
26
Your system is fine as is for 3080ti. Ram could have been cl16 but that's only minor picking. You have enabled xmp in bios yeah?
I kind of want to upgrade my case... I have a fear that the 3080TI might be too big for it... since the CPU Cooler sits in the front of my case...
I picked the wrong ram. I have the DDR4 2x16 GB 3600MHz... Vengeance RGB PRO
Isn't XMP for Intel only? I don't know what XMP does for me? Please help if you have time. I appreciate your response.
boju
Ambassador
Running ram above default Jedec speed (2133) for either Intel or Amd requires xmp (docp for Amd Asus boards). If you haven't enabled xmp then your ram isn't running at 3600. You can confirm this with cpuz memory tab, frequency value. Times frequency by two and that's your double data rate. I suspect it'll say 1066 instead of 1800.
Reactions: putern00b2020
putern00b2020
26
Very helpful thank you
Phaaze88
Ambassador
Hey now, I wasn't trying to stop you... if you want to change it, that's your choice. 🆒
All I did was take a look at Cooler Master's website and check Pcpartpicker on 3080Ti lengths. [I already knew the LF II's depth.]
Out of 47 3080Tis listed there, only 2 didn't fit, and it wasn't any of Asus' models.
putern00b2020
26
Which one would you buy within 200 dollar range? I liked the Gundam Asus one but not sure if it has good reviews
boju
Ambassador
Docp should be as easy as setting 3600 docp profile in memory settings, save & reboot. Verify speed with cpuz. Can see memory speed in Win10 task manager -> memory too but windows has been known to be flakey in it's reporting. Cpuz is more accurate.
2133 vs 3600, significant uplift in frame rates since cpu deals gpu frames first to render. Ryzen's memory controller's performance relies on memory speed so your 3070 would have been lacking, 20 or so fps maybe more, if ram wasn't running at potential.
