Question 3080Ti/Ryzen 5900x 3D Mark score with default settings
sashabcro
Commendable
May 29, 2020
20
Hi all,
On old i7 my GPU would score around 17k so I have upgraded my CPU and now it's much better, but wanted to see with you is this score of 17 449 (GPU 19 190 / CPU 11 527) with default settings alright? Everything is default, I didn't and not planing to overclock anything on my PC, so I'm wondering is this score alright or should I get more? Thanks
https://www.3dmark.com/3dm/68749915
Have no clue what that means 😀 but it runs as default 32GB (2x16GB CL16 3600Mhz)
Well in the results you posted RAM is "working" at 2128 MHz, if thats single rate then dual rate should be double ~ 4200 "MHz"
But if your RAM is 3600 and its working as intended (with XMP/DOCP enable in BIOS) then no idea what it shows anything other than (1800 / 3600)
Take the graphics and cpu scores and compare them to the average. These numbers do change over time.
5900X: 13252
3080Ti: 18464
People also push overclocks there, so the average is going to be distorted further from the norm.
There's almost no way to compare parts to non-overclocked parts anymore...
The PC does what you want it to? Then enjoy it, and ignore this.
The PC does what you want it to, but you want to endlessly chase benchmark numbers? You're on your own with that one.
Reactions: RodroX
