Question 3090 GPU Usage 100% but Clock speed around 400-800mhz.. Low FPS
Aug 17, 2022
Good Afternoon,
I am attempting to solve an issue (at least I feel likes its one) with my system running 50-60fps in New World at 1440p with ultra settings and no more than 100fps in Shadow of War at 1440p with ultra settings.
My GPU, as monitored on NZXT CAM, MSI Afterburner, and Aorus Engine, shows normally when I do not have a game launched/browsing = Low Usage, Low Temp, Normal Clock Speed ~1750Mhz.
My GPU, as monitored on either of the aforementioned software, shows abnormally when playing a game = 99/100% Gpu usuage, Normal Temp 55-65c, but low clock speed.. 400-800MHz.
CPU, RAM, etc. all looks normal in-game.
Any help would be greatly appreciated,
Thanks!
CPU : Intel Core i7-12700K @ 5.0GHz
CPU Cooler : NZXT Kraken Z53
Motherboard : Gigabyte Z690 AORUS ELITE AX DDR4
Memory : Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3600 CL18
Storage : 1x Samsung 850 EVO 250GB SSD
1x Samsung 970 Evo 1TB M.2
1x Samsung 980 Pro 1TB M.2
Graphics : Gigabyte GeForce RTX 3090 24 GB AORUS XTREME
Case : Aerocool Aero-800 ATX Mid Tower Case w/ 5x Aerocool DS 120mm Red Fan
Power : CORSAIR - RMx Series RM1000x 80 PLUS Gold Fully Modular ATX
Monitor : 1x Asus PG279Q ROG Swift 27.0" 2560x1440 IPS 165Hz 4ms G-Sync
2x LG 22MK430H-B 21.5" 1920x1080 75 Hz
Keyboard : Razer BlackWidow Elite RGB Wired
Mouse : Logitech G Pro Wireless w/ Steelseries Heavy Mousepad (Large)
Headset : Arctis Pro Wireless
Webcam : Logitech C920 HD Pro Webcam
Aug 17, 2022
Have you tried doing a CLEAN re-install of the Nvidia GPU drivers ? You can use DDU if you wish, although recommended to be used in Windows Safe Mode, it's not mandatory. Give it a try. If the problem persists, then some other issue might be there on your PC, be it software or hardware.
Your PC specs are pretty good though. I don't see any issue with that.
I’ll give that a shot as soon as I get home. I should have thought of that first. Just placed the 3090 back in the rig this week after using the 1080ti.. that may have something to do with it
Sep 10, 2022
113
17
95
Agreed with the comment above man, DDU it, if possible, update or re install the GPU bios. I’m on AMD and I recently updated the GPU bios through the website. Pretty sure NVIDIA may have such an option too?
if any above fail, f it, just clean install your windows, and if still fail RMA it 😂
Reactions: Metal Messiah.
