So I recently purchased a GTX1080 and I would really like to upgrade my monitor. Currently I have a Cheap 27" 1080p AOC monitor. My budget Is $400 and I have narrowed it down to either this Ben-Q https://www.bhphotovideo.com/c/product/1044619-REG/benq_bl3200pt_32_led_glossy.html or something like this Samsung https://www.amazon.com/Samsung-U28E590D-28-Inch-LED-Lit-Freesync/dp/B00YD3DBOC This also showed up on massdrop today https://www.massdrop.com/buy/lg-27-4k-freesync-monitor-27ud68p-b
I used to use an old 32 inch TV as a monitor and really liked the size, then I replaced that with my 27" and even though not as big, it's fine.
So when considering pixel count/screen size, would 1440p @32" Be a big improvement over 1080 @ 27"? I play games as well and I'm also trying to figure out what would be best for that. The 1080 is a beast of a gpu, but do I want to run games at 1440p on ultra settings, do I want to run at 4k on medium/high settings, or should I run 1440p on the 4k? Just confused a bit and I know a lot of the responses to this may just be opinions and that's fine.
Thanks!
Thanks!
