Question 32" 4K Monitor for productivity and gaming ?
Nov 12, 2024
Budget: Up to €1,300
Prospective Resolution: 3840 x 2160 (4K)
Screen Size: 32 inches
Aspect Ratio: 16:9
Adaptive Sync: GSync preferred (or compatible with NVIDIA)
Other Features: High text clarity for productivity and coding, Low input lag and high refresh rate for gaming, Low risk of burn-in (if OLED), Good for both productivity and gaming.
Usage Type: Primarily productivity and coding, with a focus on quality gaming (especially strategy and management games)
Hi everyone!
I’m planning to buy a new desktop PC with a configuration like this: Ryzen 7 7800X3D, RTX 4080 SUPER 16GB, and 32GB DDR5 RAM at 6000MHz. My main uses are productivity tasks, coding, and gaming—particularly strategy and management games—while I use an Xbox with an LG C3 OLED TV for other gaming genres.
Although productivity and coding will take up most of my time, I still want a high-quality gaming experience on this PC. I’m looking for a 32-inch 4K monitor (minimum 4K and 32”) and am debating between LCD and OLED options.
My main concerns are text clarity for work and the risk of burn-in with OLED screens.
Could anyone recommend specific monitor models or provide advice on choosing between these options?
Thanks so much for any insights!
How many monitors are you looking to buy?
Out of this shortlist;
https://uk.pcpartpicker.com/product...2160&F=812800000,1651000000&sort=price&page=1
I'd pick this;
https://uk.pcpartpicker.com/product...-320-3840-x-2160-144-hz-monitor-cm-9020006-na
I am curious though, you mentioned productivity and coding, would you need the monitor to rotate in order be in portrait mode?
I can do without portrait mode. It's not necessary for me. Thanks
