PAE is Physical Address Extension. It is a CPU feature that an OS can choose to use or ignore (for compatibility reasons). It's only arbitrary that the extension is only 4 bits; Intel designed it that way.
What you mean is almost every 32-bit x86 chip since the Pentium Pro has a special 36-bit addressing mode.
A 32-bit OS on a CPU without PAE wouldn't be able to address past 4 GB. It's not in the nature of a 32-bit OS to address past 4 GB of main memory. Doing so requires hardware and device driver support.
See, I don't like guessing on this because there is an even stronger argument. The 1 GB framebuffers for each 4870 are mirrored and then each core can read its own copy to render its top or bottom half, or every other frame, or however the user sets the rendering mode. Since you have 1 GB effective VRAM, the OS should have no reason to be addressing 2 GB, right?Probably two. After all the two cores won't show the same.. One renders the upper part, one the lower.
