So I recently found out that I've made the mistake of downloading a 32-bit version of Java long ago, now all of my applications that use Java are running 32-bit. Do I have to re-install every application if I correct my Java mess up or will they automatically change? I ask this because I have A TON of Java applications, and it would be a pain to find and re-install every single one.
Thanks,
Aiden
Thanks,
Aiden
