32 bit vista key for 64 bit
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I have 32 bit Windows Vista home premium installed on my PC (OEM). My question is: If I download an ISO with the same OS but in 64 bit, does the same key work (on both 64 bit and 32 bit). I have a sticker on the PC with the key on.
Yes, the key will work. Finding a safe download version of Vista may prove difficult. Beware getting from torrented sites. You will likely get more than you bargained for.
I used Vista for five years until the $15 Win8 upgrade promo and it worked fine. The way Microsoft seems to have an urge to scramble the UI around and dumb down the OS with every release is quite annoying but aside from that, I had no major issues with Vista.
Thanks for the fast answers!!!
Do you guys have any good sites to download the ISO??
PS: Always when im downloading something, i get some kind of virus, im very bad findig a good link. So im appreciating any help.
