32 Micro sd card problem (Showing as raw file system and is not able to format)
garethm56
Hi there i recently bought a 32gb micro sd card class 10 from ebay and it came 3 weeks ago. Now after sometime i had some problems so i had to keep formatting it. Now one day wanted to use it in my phone and it said "damaged sd card do you want to format it" However when did this it didn't really format it and it was just in a loop trying to fix the damaged sd card. I however put the sd card into my pc using an adapter and the drive always is not accessible and i cant even format it. I go into computer management also and it doesn't work as it shows that the drives file system is raw and there is a primary partition.
Thanks
Bump. I have tried both windows cmd repairs and doesn't work. Even tried Rufus and that doesn't work also. I am currently trying to use hdd re generator to fix it. Do you reckon it will work?
I'm not sure but you can try though.
