3200Mhz DDR4 running at 2133Mhz with XMP enabled
Jan 15, 2019
CPU: i7-7700 (non-K)
Mobo: MSI Tomahawk z270
RAM: 2x8 Vengeance LPX 3200Mhz
CMD "get speed" shows 2133/2133 as well
XMP is set to on, everything else is AUTO. I tried manually entering the timings etc but still ran at 2133... I have no Idea what to do.
CPU-Z and BIOS PICS: https://imgur.com/a/tqZtsYw)
Thanks!!!
Also, I suggest flashing the BIOS to the latest version. From what I can see, your system currently has the 1.0 version (original) of the BIOS installed. Some BIOS updates may help with memory compatibility.
Supahos
Expert
Ambassador
Note I've not tried this, but I know older intel.locked chips weren't capable of pushing memory as fast as their k series counterparts. It's possible it just can push the ram that far, start with 2666 and step up to 2933 just kind of see if there's a wall somewhere and it'll confirm your bios memory settings actually work
Jan 15, 2019
I was in the process of flashing as I read this but it worked afterwards. Thanks!
