Question 3200mhz or 3000mhz for my build?
Clueless1200
50
Hey, so uuuh, cut a long story short, I'm about to build a new rig and I'm in a position where I could get my ideal RAM choice at 3000mhz right now, or 3200mhz in a couple of weeks. I'll be using it with a 2070 Super, Ryzen 3700X, MSI B450 Gaming Pro Carbon AC motherboard. Playing at 1440p with a high refresh rate. Is it worth waiting for the 3200mhz or not?
Thanks in advance.
stefanos50
421
109
490
29
Well at 1440p cpu is the bottleneck so it will not affect the performance that much. Also you can just pick the 3000Mhz and overclock it to 3200Mhz or even higher if the kit can go (it is not guarantee if it will clock without any problem though)
Reactions: Clueless1200
extreme_noob
Notable
Jul 30, 2018
408
25
840
11
Would configuring the timings of the 3000 to match the 3200 be a decent option? Only just found out that was possible, lol.
If by timings you mean increasing clock speed, sure if you're up to it. From what I've heard its even more tedious than CPU overclocking though, so just get 3200 MHz ram.
Timings is a different thing though. Generally, you want lower timings, and higher clock speed RAM will have higher timings. For now, just ignore timings as 3200MHz CAS Latency 16 (Probably what your 3200 ram would be considering price) will still be faster than 3000MHz CAS Latency 15.
