[SOLVED] 3200mhz ram only running at 2933mhz
Parroty69
Commendable
Oct 27, 2021
240
7
1,595
I noticed my ram Userbenchmark score was a little low, here is my test result:
https://www.userbenchmark.com/UserRun/47579801
I have a 10750h cpu with 16gb of ram but it's only running at 2933mhz
Here is the task manager:
View: https://imgur.com/ZYhFEd7
Here is the memory section of cpu-z:
View: https://imgur.com/qeBUFF3
Here is SPD section of cpu-z slot 1:
View: https://imgur.com/PdhpDn5
Here is SPD section of cpu-z slot 3:
View: https://imgur.com/NyCHxTZ
Can you please help me fix this issue?
Does my laptop have overclocking? It is a g712l from ROG
Does my ram support xmp?
from https://rog.asus.com/laptops/rog-strix/rog-strix-g17-series/
*DDR4-3200 RAM is limited to configurations equipped with an Intel® Core™ i7-10870H and up with RTX graphic card model. Rest of the model can only support to DDR4-2933. CPU configuration may vary according to regions. Please check with local vendors for exact offers.
ROG carefully chooses advanced components to ensure system stability and performance. To deliver the best experience, we use DDR4-3200 memory running at 1.2V. Reaching that speed with third-party modules is not guaranteed. Please contact your local ASUS support center for more details on memory...
ROG carefully chooses advanced components to ensure system stability and performance. To deliver the best experience, we use DDR4-3200 memory running at 1.2V. Reaching that speed with third-party modules is not guaranteed. Please contact your local ASUS support center for more details on memory upgrade options.
My laptop can only use 2933mhz. That's a bummer!
