[SOLVED] 3200mhz running at 1600
Run CPUZ and open the Memory tab, and select a module, it will show you what speed it's running. Look for DRAM Frequency. It should read 1600 there if your ram is running at full speed. As @ChumP, has said it's double data rate, so 1600= 3200mt/s
