Question 3200mhz running at 2400
Dec 26, 2018
32
I bought a new hyper x fury DDR4 3200mhz 32GB Ram with asus prime z390 a MOBO, but Asus BIO shows that my RAM is running at 2400. If I want to raise the speed to 3200mhz, then is it means that I overclock them or overclocking means speed goes higher than 3200mhz? Goal is to get 3200mhz
Jul 17, 2019
35
6
35
It is not exactly overclocking. You are just overclocking the RAM to the advertised settings, using XMP profiles. Find RAM settings and set it use to use XMP profiles. It would just be fine.
