and your motherboard/cpu need that
Thanks. I do have a older Asus K30AD. Is this one upgradable? A lot of parts could be combined such as my RAM from the HP to the Asus and such. Stupid idea or..?Required Power Supply 450 Watt
Additional Requirements adjacent PCI slot, two additional power connectors
Sapphire Radeon HD 5750 (PCI-e 2.0, 1GB GDDR5) Specs
Sapphire Radeon HD 5750 (PCI-e 2.0, 1GB GDDR5) overview and full product specs on CNET.www.cnet.com
Power Supply Upgrade for a HP Compaq Elite 8300 CMT
https://h30434.www3.hp.com/t5/Deskt...e-for-a-HP-Compaq-Elite-8300-CMT/td-p/6928080
Does not look to be very upgradeable.
Ok i'm lost. My pc has the powersupply mentioned, which is factory standard.
So what do you mean with
With that system ready for a decade of games i haven't played, i will definitely get into pc building. Things start to make sense, so much i can't believe i didn't 'get it' before.That said, if you want to LEARN about building PC's and join the PCMR, I suggest getting a new case (ATX standard), new PSU (ATX standard), and new motherboard (ATX standard), and migrate your drive, RAM, CPU, etc. over to the new build and then install the new graphics card that will allow you to play more than Minecraft.
