Okay, so a few months ago, I moved from 32bit Windows 7, to 64bit Windows 7 in order to support the 4GB of ram in my rig.
Problem is, ever since then, I've had 2 problems.
First off, W7 64bit will only operate correctly if I downclock the RAM to 667mhz (otherwise everything crashes, BSOD or black screens).
And the really annoying problem, is that a lot of my games don't play as well, eg. TF2, I average around 50fps, somtimes dips as low as 30, and I used to be able to get constant 75fps with vsync ON.
Should I go back to 32bit and sacrifice some of my ram, or does this sound like another problem?
Just for the record, I've tried running 64bit with the 2GB at 800MHz like I used to with 32bit, but it made no difference.
Just incase it helps, I have a Q6600 2.8GHz, 4GB 800MHz DDR2 RAM, and a GTX465 1GB 800/1900.
