[SOLVED] 32g 3200Mhz have issues with b450 tomahawk
Jan 6, 2019
16
i have
g-skill fleareX 32G 4 sticks 3200Mhz 16 18 18 38,
Ryzen5 2600,
B450 msi Tomahawk
when i open xmp profile 2 3200 the pc Become Unstable , windows not loading and tell me "there isn't enough memory"
and another error "File:\windows\system32\drivers\evbda.sys
in general not stable when i bot xmp 2966 the pc turn to good and stable
i tried every thing " i close xmp,and entered static frequency 3200" no way the problem is still there
helpstar
Illustrious
did you reset the BIOS after the flashing completed successfully?
Did you try using only dual channel 2x8GB with 3200MHz with the new RAM?
Install the modules in Dimm Slot A2 and B2
Did you buy two dual channel kits 2x8GB + 2x8GB and not a 4x8GB kit?
Reactions: tamer.eldesouky
Jan 6, 2019
16
yes i try using only dual channel 2x8GB with 3200MHz and it work well
and yes i buy two dual channel kits 2x8GB + 2x8GB
Jan 6, 2019
16
What if i use 8x3 only with 3200 Mhz... it work well or not ??
and i read on amd website the 2nd G it support 2966 Mhz and 3rd G support to 3200 Mhz of ram.. that is true ????
helpstar
Illustrious
Jan 6, 2019
16
8x3 will work in dual channel as well, but if more than 16GB will be needed, the other 8GB will work in single channel.
https://www.intel.com/content/www/us/en/support/articles/000005657/boards-and-kits.html#dual
Would run with 2933MHz with 4 sticks.
Check each stick with memtest.org usb autoinstaller while XMP is enabled. A bad module could be a reason for not working well too.
Did you reset the BIOS via jumper yet?
i tested each stick its work well ,, the problem is when i but the 4 sticks and open xmp on 3200 it happen a lot of problems when i open xmp on 2966 there no problems
Jan 6, 2019
16
The AMD 2000 sereis cpu memory Controller is 2933mhz natively and will default the ram speed to that when all ram slots are populated.
NO mother board will not change that fact.
With alot of trying different settings you Might get lucky to run 3200 otherwise you are looking at 2933mhz.
if i change the cpu to 3rd generation like ryzen 5 3600X, i think it work with 3200
Reactions: Crosslhs82x2
