Question 32Gb G.Skill Trident Z (Neo F4-3600C16D-32GTZN) compatible with Meg X570 Ace?
TheMightyChuckaboo
69
As the title suggests, I just wanted to confirm whether or not G.Skills Trident Z Neo (2x16gb) (F4-3600C16D-32GTZN) are in fact compatible with the X570 ACE. I only ask as I cannot for the life of me see it on MSI' QVL section and want to make absolutely sure. That, or I am blind. Thanks in advance everyone!
Just finished building with below spec
msi meg x570 ace
amd ryzen 9 3900x
gskill trizent z neo 32gb (2x16gb) (F4-3600C18D-32GTZN) mine is 18D not 16D
I was able to boot, install windows 10, did all the updates on windows, bios, drivers, etc...
But when I enable xmp to recognize 3600mhz rams, the system would not post. So I had to reset cmos back to default setting for bios...
Trying to find a solution but no luck so far...
G.Skill RAM Configurator lists it as compatible for your board-
RAM Configurator results
Actually, GSkill homepage shows as it's compatible but on MSI QVL list, it's NOT listed as compatible.
https://www.msi.com/Motherboard/support/MEG-X570-ACE#support-mem-19
I purchased F4-3600C18D-32GTZN because GSkill QVL said it's compatible with meg x570 ace, but found out it's not on MSI QVL list, so ended up switching to F4-3600C16Q-32GTZNC. But still wasn't able to change the setting in Bios to full 3600Mhz. I was only able to set it up to 3466 16CL. Maybe I need to OC cpu to get full speed of the rams...?
