350$ system, need suggestions.
mjmjpfaff
Approximate Purchase Date: within the next 2 months
Budget Range: 350$ after rebates
System Usage from Most to Least Important: surfing the internet.
Parts Not Required: mouse, os, monitor
Preferred Website(s) for Parts: newegg if it is the best deal including CA taxes. mostly from amazon to avoid taxes.
Country of Origin: US, california
Parts Preferences: none
Overclocking: no
SLI or Crossfire: no
Monitor Resolution: 1600x900
Additional Comments: needs to be cheap, need speakers, keyboard, and mouse pad
i3 2100- http://www.amazon.com/gp/product/B004JEVGMO/ref=ox_sc_act_title_10?ie=UTF8&m=AZ8ZZL30AH7DI 125$
ASRock H61M-VS- http://www.amazon.com/gp/product/B004S9JXPW/ref=ox_sc_act_title_9?ie=UTF8&m=ATVPDKIKX0DER 55$
PNY 4gb 1333mhz- http://www.amazon.com/gp/product/B0026ZPTR6/ref=ox_sc_act_title_7?ie=UTF8&m=ATVPDKIKX0DER 28$
Western Digital 500gb hdd- http://www.amazon.com/gp/product/B00461G3MS/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DER 45$
Corsair CX 430w- http://www.amazon.com/gp/product/B004W2T2TM/ref=ox_sc_act_title_8?ie=UTF8&m=ATVPDKIKX0DER 35$
NZXT Gamma Mid Tower Case- http://www.amazon.com/gp/product/B002UDK9U6/ref=ox_sc_act_title_6?ie=UTF8&m=ATVPDKIKX0DER 36$
Logitech K120 keyboard- http://www.amazon.com/gp/product/B003ELVLKU/ref=ox_sc_act_title_4?ie=UTF8&m=ATVPDKIKX0DER 12$
Logitech S120 Speakers- http://www.amazon.com/Logitech-S120-2-0-Multimedia-Speakers/dp/B000R9AAJA/ref=sr_1_7?ie=UTF8&qid=1315872499&sr=8-7 10$
3M Mouse Pad- http://www.amazon.com/gp/product/B0017D5Z40/ref=ox_sc_act_title_4?ie=UTF8&m=ATVPDKIKX0DER 6$
Total=352$
In the next two months, there will be a black friday sale and AMD's new processors would be released. Ask again in the next 3months and 2 weeks. It's a waste to ask now since there would be major price changes in the months ahead.
good point. has anyone seen anything on bulldozer? tomshardware just did something on sandy bridge extreme it seems that there needs to be some sort of stats out now.
that ram is 12 cents less than the pny ram i posted after tax. it doesnt have heatsinks too. i know ddr3 does not need heatsinks but they look cool. and i just did the math on a psu calculator. you have to remember i am not running much stuff and it isnt oc'd. with a 560 ti it takes up about 280w a 430w psu should be fine. and i totally forgot about microcenter that will save me like 15$ thanks.
If your primary need is to surf the internet, you might want to check out this...
AMD Llano CPU ($99): http://www.newegg.com/Product/Product.aspx?Item=N82E16819103951
FM1 Socket Motherboard ($75): http://www.newegg.com/Product/Product.aspx?Item=N82E16813157260
You'll end up with slightly less CPU power but vastly superior GPU power (equiv to Radeon HD 6530)... it's also a few bucks cheaper, too. The i3 and Llano CPUs are both overpowered for Internet browsing, so in my book, it's better to have a bit more bandwidth on the GPU side... the integrated Intel GPUs are barely enough to run a 1080p monitor and you can forget about BlueRay.
Of course, if you end up with a GTX 560, this is all moot.
Also, save $4 and get a $2 mouse pad from Walmart.
Quad cores are better than the i3 if you plan on surfing the 2 extra cores will make your computer faster for multitasking. ^_^
well i have a 560 ti in my gaming computer when i upgrade it i will put the 560 ti in the computer i want to build now
also performance/quality parts over looks
in the same ballpark is the x4 955. i will not be overclocking because i do not have room for a cpu cooler (i think) and the i3 2100 is better at stock and you would have to oc the 955 a good amount to match the performance. remember the i3 2100 has hyperthreading which makes its 2 cores into 4 threads
