First off, I'm gonna warn you that this is going to be a long post.
It's just a very complicated issue, especially because of the nature of these items; I want the best for the money that I have to spend, I don't want to buy the wrong piece, I don't want to regret not taking enough time to analyze things, etc.
With that being said lets establish the guidelines of this build:
Alright, lets start talking about some parts, what I consider the “backbone” of all the various possibilities for my final build;
before talking about the different possibilities that I had in mind, I want to talk about the pieces that don't change between them, since they mostly affect CPUs and motherboards:
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler (€89.90 @ Amazon Italia)
Memory: G.Skill - Ripjaws V Series 32GB (2 x 16GB) DDR4-2800 Memory (€250.88 @ Amazon Italia)
Storage: Samsung - 960 PRO 512GB M.2-2280 Solid State Drive
Storage: Toshiba - X300 4TB 3.5" 7200RPM Internal Hard Drive (€151.82 @ Amazon Italia)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Extreme Video Card (€891.30 @ Amazon Italia)
Case: Phanteks - Enthoo Pro ATX Full Tower Case (€107.99 @ Amazon Italia)
Power Supply: SeaSonic - 760W 80+ Platinum Certified Fully-Modular ATX Power Supply (€156.67 @ Amazon Italia)
Optical Drive: Lite-On - iHAS124-14 DVD/CD Writer (€15.92 @ Amazon Italia)
Total: €1664.48
Generated by PCPartPicker 2017-10-30 03:49 CET+0100
_______________________________________________________________________________
Lets start with the cooler:
of course the cooler will actually change with the CPUs and motherboards, but this was actually to spark a question about the type of coolers.
I think that, in general, it is better for me to get the best non-liquid cooler possible(that's why I just put the best Noctua I could find), because I really care about temps and want my CPU to be chill at all times, but I'm afraid of liquid coolers failing me.
So; am I right? Or are there COMPLETELY SAFE, 100% risk free liquid coolers?
Because I don't care how “theoretically safe” and “with really low margin of failure” some liquid coolers now are, I ain't risking a 3500€ computer on a 200€ cooler, nu-uh.
So I think I should just go for the best non-liquid cooler and that's usually the most expensive Noctua, right?
Then, the RAM.
32 gb is not negotiable. Then I picked the one between 2400-2800 with the lowest CAS(14) and the best price/value ratio on pcpartpicker.
Why 2400-2800? Because most CPUs don't support more than that without Ocing and I'm not gonna OC my ram.
Next, the storage.
1 SSD and 1 HHD are mandatory.
This SSD is from what I've heard the best when it comes to price/value ratio, and I don't need 1 tb of it since I will just put the OS, some crucial software(OBS, Steam, etc.) and some games in it.
Games and softwares & files that don't require to load incredibly fast, or are just old and don't need that much power will just be put in the HDD.
Am I wrong? Should I get 1 TB of SSD even if its double the price? Or a different kind of SSD?
Now, the graphic card.
1080 ti of course, not even a question.
I've picked the 11 GB with the highest core clock I could find and the price isn't even that high considering other cards, BUT if you know cards that are better in;
Let me know; I REALLY want a graphic card that is powerful and remains cool primarily. Quietness is an important secondary role, but secondary nonetheless.
The graphic cards leads me to the power supply;
I was undecided between this, and the 1050W variant of it, because I'm debating whether or not I will be running double 1080tis in the future when I will be in need of an upgrade, or just buying the best next-gen graphic card available.
What do you people think? What is better to do?
I think I'll just buy the next-best graphic card, but I'm always all ears.
Also, do you know any better PSU? I feel I can't go wrong with that, beside the SLI question.
Or do you think SeaSonic doesn't make good PSU? Or there are just better PSUs for a similar price? Let me know.
And for last but not least, the case.
Now, I've thought a lot about how to choose a case, and I still have doubts. I just picked this case as a min. standard.
I want the case to be:
with VERY good airflow, as spacious as possible, has dust filters, and as silent as possible, in this order.
So I naturally went the full tower way.
Now, I chose this case because I've read that is both quiet and allows for a lot of fans to be mounted, and there's dust filters over all the fans.
But is it the best for the price? Or is it good at all? I don't mind spending even double the price of this case for a drastically better one.
I REALLY don't want my case to be hot/retain hot air because of poor air flow due to poor space management or bad design or whatever, and I will GREATLY appreciate a case that quiets most of my noise(due to CPU cooler, graphic card, etc.).
It HAS to have dust filters because dust is not only bad for my health, but also impacts the performance of my computer.
Also I like the side-glass thingy but I'd rather have a fully silent case than a pretty one, but if I can have both for a price not too high, why not?
But the price can't be too high since I wont cut the budget from other pieces for the aesthetics of the case.
Also, am I good with stock fans or do I need to buy new ones?
And how many/ for how many sides? Again I don't care for RGB stuff(and again, I mean its nice but I'm not gonna spend MORE money for RGB pieces), its just to have very good airflow.
Now, lets discuss the different possibilites/combinations when it comes to CPUs.
My doubts are about two, consecutive questions.
Now let me explain the first question.
If single box, I can buy a very powerful computer that can satisfy my needs at the moment, and then in the future, if I want and have money for it, I can use my current computer to cannibilize some parts and build a very cheap but effective streaming box, something that would look kinda like this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (€196.46 @ Amazon Italia)
CPU Cooler: Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler (€29.88 @ Amazon Italia)
Motherboard: ASRock - A320M-DGS Micro ATX AM4 Motherboard (€53.99 @ Amazon Italia)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-2133 Memory (€156.99 @ Amazon Italia)
Storage: ADATA - Premier Pro SP600 128GB 2.5" Solid State Drive (€78.73 @ Amazon Italia)
Storage: Toshiba - 1TB 3.5" 7200RPM Internal Hard Drive (€45.97 @ Amazon Italia)
Video Card: Sapphire - Radeon HD 7970 3GB Video Card
Case: Antec - GX700 ATX Mid Tower Case
Power Supply: Antec - High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply
Total: €562.02
The graphic card, PSU and case are the ones I'm currently using(and I think the cooler too but I'm not too sure rn).
If I go dual box route, I should use some of my budget to fund the parts for the streaming box that I just linked, thus having less to spend on the primary rig, making it less powerful. The primary rig would run Intel for sure tho, and maybe I could pick a less expensive CPU, like an i7-7700k.
Not only that, but from my understanding dual box comes with a lot of software n hardware issues that I don't know if I'm ready to face right now, right at the start of this streaming thing, and I kind of like the simplicity of having just one computer to worry about at the start; then, if I see that I really like streaming everyday and want to specialize even more and want to have everything maxed out, I'll buy the second, streaming-dedicated box, to compliment an already beast of a primary pc.
Tl;dr: For simplicity I'd prefer a single box, do you think its wrong?
Then, assuming I'd go with single box, comes the AMD vs Intel question.
Since a single computer would be handling both gaming and streaming, the CPU needs to perform excellently.
So the question is; do I use a Threadripper 1900x that apparently is better for streaming but not gaming(or even higher Threadrippers is they manage to stay in budget but I think their single core performance might be too low and I dont need that many cores), or a an Intel CPU?
And if Intel, which one?
For reference, I have had my eyes on the i7-7820X 3.6GHz 8-Core, and then the Core i7-8700K 3.7GHz 6-Core even if pcpartpicker doesn't have it as available in Italy at the moment ; the i9-7900X 3.3GHz 10-Core could be an option if I can find one in Italy and it somehow manages to stay inside the budget.
I'll show you the different builds and then I'll link some benchmarks results;
i7 7820x;
CPU: Intel - Core i7-7820X 3.6GHz 8-Core Processor (€624.17 @ Amazon Italia)
Motherboard: MSI - X299 RAIDER ATX LGA2066 Motherboard (€238.99 @ Amazon Italia)
Total: €2527.64
i7 8700k;
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard (€112.98 @ Amazon Italia)
Total: €1777.46
TR 1900x;
CPU: AMD - Threadripper 1900X 3.8GHz 8-Core Processor (€548.92 @ Amazon Italia)
CPU Cooler: Noctua - NH-U14S TR4-SP3 140.2 CFM CPU Cooler (€79.90 @ Amazon Italia)
Motherboard: ASRock - X399 Taichi ATX TR4 Motherboard (€345.20 @ Amazon Italia)
Total: €2548.60
Now, the benchmarks:
8700k vs 7820x: http://cpu.userbenchmark.com/Compare/Intel-Core-i7-8700K-vs-Intel-Core-i7-7820X/3937vs3928
7820x vs 1900x: http://cpu.userbenchmark.com/Compare/Intel-Core-i7-7820X-vs-AMD-Ryzen-TR-1900X/3928vsm340638
8700k vs 1900x: http://cpu.userbenchmark.com/Compare/Intel-Core-i7-8700K-vs-AMD-Ryzen-TR-1900X/3937vsm340638
So by these results, looks like the 7820x is straight up better than the 1900x, and at the same time almost the same performance as the 8700k but better for the multi-core; but these are just numbers, and I've heard everybody say that Threadripper is straight up better for streaming, so I don't really know???
I'm very undecided on this issue, and no information seems to sway me.
What do you guys think? Do you have any other CPUs in mind that might be provide better performance than these(beside i9s :^] )?
Also; what about the mobos?
Let's say that I go for the 7820x; would that mobo be good enough?
I've chose pretty randomly; one of the cheapest with enough features, but for example I've seen some screens online and the m.2 slot looks kinda hard to fit with the future graphic card(s)... so do you guys know a better one?
And what feature should I look for beside m2 slots, sata 6, enough usb3.0 slots etc.?
Let me know if you have any suggestions, idea, correction, or any sort of input or interest for my build, and if you've read all this, thank you for your time!
P.s.: I know this formatting of mine isn't good; I'm not used to it!
- I'm assembling this pc because my current one is pretty old(approaching 6 years) and breaking down.
- I'm using this chance to go all-out and try to build a very good 1)gaming, 2) streaming and 3) video-editing computer.
The priorities are those since the games have to run at a very good quality for my enjoyment and in order to stream them at an high quality; the and video-editing is just a secondary function, I wont edit/upload videos often, and they will often just be stream highlights.
- I have a very big budget (-3500€-3700€+), but me having a big budget doesn't mean I want to spend it all and I'll appreciate cutting a cost if not needed; I don't care for RGB stuff(I mean its nice but I'm not gonna spend MORE money over it) or “paying for brand”, and I prefer “quality”, or rather, “utility/functionality” over “aesthetics”, and I don't want to cut a cost that will impact the performance of my computer(and the temps, or the quietness; I need the computer to be cool during heated and humid summers, and quiet because the noise could disrupt the quality of the streaming) in the long run, since I don't plan to change any computer parts anytime soon; you could say that I'm “future proofing” but I don't want to change parts to this computer until they break or get incredibly old, so tl;dr;
- Videogames and streaming are the priority, video-editing is secondary
- Don't care for aesthetics but only for functionality; performance, temps and quietness, and don't want to “pay for brand” but for quality
- Want to use my budget to the fullest to avoid having problems in the future but also not willing pay for overpriced stuff that have no effect
Total: €1664.48
Then, the RAM.
Next, the storage.
- temperatures under long period of times
- quieter
- or are just cheaper with the same performances
- single box or dual(gaming+streaming) box?
- if single box, AMD or Intel?
Total: €562.02
i7 7820x;
Total: €2527.64
i7 8700k;
Total: €1777.46
TR 1900x;
Total: €2548.60
